Allwinner V853 SoC combines an Arm Cortex-A7 core with a Xuantie E907 RISC-V core, and a 1 TOPS NPU for cost-sensitive AI Vision applications such as smart door locks, smart access control, AI webcams, tachographs, and smart desk lamps .
Manufactured with a 22nm process, the SoC comes with an ISP image processor and Allwinner Smart video engine capable of up to 5M @ 30fps H.265/H.264 encoding and 5M @ 25fps H.264 decoding, offers parallel CSI and MIPI CSI camera interfaces, and well as MIPI DSI and RGB display interfaces.
Allwinner V853 specifications:
- CPU
- Arm Cortex-A7 CPU core @ 1 GHz with 32 KB I-cache, 32 KB D-cache, and 128 KB L2 cache
- Alibaba Xuantie E907 RISC-V core with 16 KB I-cache and 16 KB D-cache
- NPU (Neural network Processing Unit) – Up to 1 TOPS for V853 and 0.8 TOPS for V853Sembedded 128KB internal buffer, support for TensorFlow, Caffe, Tflite, Pytorch, ONNX, etc..
- VPU (Video Processing Unit)
- Encoding
- H.265/H.264 encoding up to 3840×2160 @ 20fps
- Multi-stream real-time encoding up to 5M @ 25fps + 720p @ 25fps
- MJPEG/JPEG baseline encoding up to 1080p60
- Decoding – H.264/JPEG decoding up to 16 megapixels (4096×4096)
- Encoding
- Memory I/F – 16-bit DDR3/DDR3L
- Storage I/F – SD 3.0/eMMC 5.1 flash, SPI NOR/SPI NAND flash
- Video Output
- 4-lane MIPI DSI up to 1920 x 1200 @ 60fps
- RGB interface with DE/SYNC mode up to 1920 x 1080 @ 60fps
- Video Input
- ISP supporting up to 5M @ 30 fps, and a maximum resolution of 3072 x 3072
- Parallel CSI supporting 8/10/12/16-bit width
- 4-lane MIPI CSI input or two 2-lane MIPI CSI inputs; maximum video capture resolution up to 5M @ 30fps
- Audio
- 1x 16-bit/20-bit DAC with 8 kHz to 192 kHz sample rate
- 2x 16-bit/20-bit ADC with 8 kHz to 48 kHz sample rate
- 2x differential microphone inputs: MICIN1P/N, MICIN2P/N
- 1x differential lineout output (LINEOUTP/LINEOUTN)
- 2x I2S/PCM external interfaces (I2S0, I2S1)
- Up to 8 digital PDM microphones with sample rates from 8 kHz to 48 kHz
- Other Peripherals
- 5x TWI (I2C) interfaces, 4x UART interfaces, 4x SPI interfaces
- 8x GPIO, 1x 12-ch PWM controller
- 4x general-purpose analog-to-digital converter (GPADC)
- USB 2.0 DRD
- Package – LFBGA 318
- Process – 22nm
A thread on a Chinese forum mentions the NPU on V853 is “very open” not like the one on V831, and Allwinner also provides a V851 model with 64MB or 128MB built-in memory. The Allwinner R853 is the same but designed for robots with motor control. I suppose R853S shown above is a variant with a 0.8 TOPS NPU like for V853S… More details specifications can be found on linux-sunxi website. The Arm Cortex-A7 should probably run Linux (OpenWrt based on TinaLinux?), and the RISC-V MCU core handles low power modes and I/Os, but it is not entirely clear how they work together, and which core handles what.
MangoPi team is also working on a compact (27.5×42.5 mm) MQ-V Ai Core module based on Allwinner V853 with 512 MB DDR3, 8GB eMMC flash, and an AXP2101 PMU, so we’ll certainly find out more in a couple of months.
