view = “model”; // viewing mode “platter”, “model”, “debug”
case_design = “tray”; // “shell”, “panel”, “stacked”, “tray”
case_style = “vu5”; // style of case_design
// tray: none, vu5
sbc_model = “c4”; // any sbc from sbc model framework: “c1+”,”c2″,”c4″,”hc4″
// “xu4″,”xu4q”,”mc1″,”hc1″,”n1″,”n2″,”n2+”,”h2″
pcb_loc_x = 5; // sbc location x axis
pcb_loc_y = 0; // sbc location y axis
case_offset_x = 0; // additional case x axis size
case_offset_y = 0; // additional case y axis size
case_offset_tz = 0; // additional case top z axis size
case_offset_bz = 4; // additional case bottom z axis size
wallthick = 2; // case wall thickness
floorthick = 2; // case floor thickness
sidethick = 3; // case side thickness
gap = 1.5; // distance between pcb and case
indents = true; // indentations around io openings
sidewall_support = true; // enable wall support for standoffs
sbc_top_standoffs = false; // enable sbc top standoffs
sbc_bottom_standoffs = true; // enable sbc bottom standoffs
case_ext_standoffs = false; // enable case extended standoffs
sata_punchout = true; // enable sata punchout
gpio_opening = “none”; // gpio openings “none”,”vent”,”open”,”punchout”
cooling = “fan”; // “none”, “vents”, “fan”, “custom” using ./dxf/customfan.dxf
exhaust_vents = “vent”; // exhaust vents “none”,”vent”
fillet = 0; // edge fillets
