Home > Press > Development of high-durability single-atomic catalyst using industrial humidifier: Identification of the operating mechanism of cobalt-based single-atomic catalyst and development of a mass production process. Utilization for catalyst development in various fields including fuel
(a) single-atomic catalyst synthesis process using humidifier method, (b) SEM image, (c) cobalt element mapping image, (d) high-resolution STEM image of cobalt single-atomic catalyst CREDIT Korea Institute of Science and Technology (KIST) ) |
Abstract:
Fuel cell electric vehicles (FCEVs) are an eco-friendly means of transportation that will replace internal combustion locomotives. FCEVs offer several advantages such as short charging time and long mileage. However, the excessive cost of platinum used as a fuel cell catalyst leads to limited supply of FCEVs. There has been extensive research on non-precious metal catalysts such as iron and cobalt to replace platinum; However, it is still challenging to find alternatives for platinum due to the low performance and low stability of non-precious metal catalysts.
Sejong, Korea | Posted on May 13th, 2022
The research team led by Dr. Sung Jong Yoo of the Hydrogen·Fuel Cell Research Center at Korea Institute of Science and Technology (KIST, President Seok Jin Yoon) conducted joint research with professor Jinsoo Kim of Kyung Hee University and professor Hyung-Kyu Lim of Kangwon National University; they announced that they have developed a single atomic cobalt-based catalyst with approximately 40% improved performance and stability compared to contemporary cobalt nanoparticle catalysts.
Conventional catalysts are typically synthesized via pyrolysis, wherein transition metal precursors and carbon are mixed at 700–1000℃. However, due to metal aggregation and a low specific surface area, the catalysts obtained through this process had a limited activity. Accordingly, researchers have focused on synthesizing single-atomic catalysts; However, previously reported single-atomic catalysts can only be produced in small quantities because the chemical substances and synthesis methods used depending on the type of the synthesized catalyst . Therefore, research has focused on performance improvement of the catalyst rather than the manufacturing process.
To address this problem, the spray pyrolysis method was implemented using an industrial humidifier. Droplet-shaped particles were obtained by rapidly heat-treating the droplets obtained from a humidifier. This can enable mass production through a continuous process, and any metals can be easily produced into particles. The materials used for the synthesis of metal particles should be water-soluble because the particles are made through an industrial humidifier.
It was confirmed that the cobalt-based single-atomic catalysts developed through this process exhibit excellent stability as well as fuel cell performance and are 40% superior compared to conventional cobalt catalysts. Cobalt-based catalysts also cause side reactions in fuel cells; However, computational science has shown that catalysts manufactured via spray pyrolysis lead to forward reactions in fuel cells.
Dr. Yoo clarified, “Through this research, a process that can enable considerable improvement in the mass production of cobalt-based single-atomic catalysts has been developed, and the operating mechanism of cobalt-based catalysts has been elucidated via close analyses and computational science. These results are expected to serve as indicators for future research on cobalt catalysts.” They also added, “We plan to expand the scope of future research to explore not only catalysts for fuel cells, but also environmental catalysts, water electrolysis, and battery fields.”
About National Research Council of Science & Technology
KIST was established in 1966 as the first government-funded research institute to establish a national development strategy based on science and technology and disseminate various industrial technologies to develop major industries. KIST is now raising Korean science and technology status through world-leading innovative research and development. For more information, please visit our website at https://eng.kist.re.kr/kist_eng_renew/
This research was supported by the KIST Institutional Program, Climate Change Technology Development Project Nano·Material technology development project, which are funded by the Ministry of Science and ICT (Minister, Hyesook Lim) The research results were published in the latest issue of Applied Catalysis B: Environmental (IF: 19.503 JCR top 0.926%), an international journal in the field of energy and the environment.
For more information, please click here
Contacts:
Mira Lee
Office: 44-287-7374
Cell: 01-9800-1732
Expert Contacts
Dr. Yoo, Sung Jong
Office: +82-2-958-5260
Lee, Yeeun (PR Department)
Office: +82-2-958-6929
Copyright © National Research Council of Science & Technology
If you have a comment, please contact us.
Issuers of news releases, not 7th Wave, Inc. or Nanotechnology Now, are responsible for the accuracy of the content.
Bookmark:
ARTICLE TITLE
News and information
Engineering piezoelectricity and strain sensitivity in CdS to promote piezocatalytic hydrogen evolution May 13th, 2022
New nanomechanical oscillators with record-low loss May 13th, 2022
Small microring array enables large complex-valued matrix multiplication May 13th, 2022
Study finds nanomedicine targeting lymph nodes key to triple negative breast cancer treatment: In mice, nanomedicine can remodel the immune microenvironment in lymph node and tissue for long-term remission and lung elimination tumor in this form of metastasized breast tumor cancer May 13th, 2022
Chemistry
Water processing: light helps degrade hormones: KIT researchers use polymer membranes coated with titanium dioxide for photocatalytic cleaning – results are reported in Nature Nanotechnology April 22nd, 2022
Flexible quantum sieve made at TU Dresden filters the fuel of Starship Enterprise April 15th, 2022
Photocatalysts with built-in electric field helps to remove pollutants from water April 15th, 2022
Researchers redefine how liquid and solid layers stick together based on molecular forces: New study reveals how intermolecular forces inform the design of smart materials April 8th, 2022
Possible Futures
Discoveries
Going gentle on mechanical quantum systems: new experimental work establishes how quantum properties of mechanical quantum systems can be measured without destroying the quantum state May 13th, 2022
Announcements
Interviews/Book Reviews/Essays/Reports/Podcasts/Journals/White papers/Posters
Lightening up the nanoscale long-wavelength optoelectronics May 13th, 2022
On-Chip Photodetection: Two-dimensional material heterojunctions hetero-integration May 13th, 2022
Energy
Faster, more efficient nanodevice to filter proton and alkaline metal ions: Monash University researchers have developed a faster, more efficient nanodevice to filter proton and alkaline metal ions which will help design next-generation membranes for clean energy technology, conv April 8th, 2022
USTC found a pathway to high-quality ZnSe quantum wires April 8th, 2022
Three dimensional Mn-doped NixSy/Ni2P and Mn-doped Ni2O3/Ni2P nanosheets as efficient electrocatalysts for alkaline overall water splitting April 8th, 2022
Water
The future of desalination? A fast, efficient, selective membrane for purifying saltwater May 13th, 2022
The deformation of the hydrogel is used to measure the negative pressure of water April 22nd, 2022
Battery Technology/Capacitors/Generators/Piezoelectrics/Thermoelectrics/Energy storage
Achieving higher performance with potassium ion battery April 15th, 2022
Interdisciplinary team studies challenges and prospects of lithium-CO2 dioxide batteries April 8th, 2022
Fuel Cells
Scavenger nanoparticles could make fuel cell-powered vehicles a reality April 1st, 2022
Graphene gets enhanced by flashing: Rice process customizes one-, two- or three-element doping for applications March 31st, 2022
Activating lattice oxygen in perovskite oxide to optimize fuel cell performance December 17th, 2021
Gamechanger for clean hydrogen production, Curtin research finds: Curtin University research has identified a new, cheaper and more efficient electrocatalyst to make green hydrogen from water that could one day open new avenues for large-scale clean energy production September 17th, 2021
