Nanotechnology Now – Press Release: Highest degree of purity achieved for polarized X-rays: Helmholtz Institute Jena opens up new possibilities at the European X-ray laser European XFEL
Home > Press > Highest degree of purity achieved for polarized X-rays: Helmholtz Institute Jena opens up new possibilities at the European X-ray laser European XFEL
The experiments took place at the European XFEL. CREDIT © European XFEL/Heiner Müller-Elsner
Abstract:
A research team was able to generate polarized X-rays with purity at the European XFEL in Hamburg. The experiments involved scientists from the Helmholtz Institute Jena, a branch of GSI, Friedrich Schiller University Jena and the Helmholtz Center Dresden-Rossendorf. The method is supposed to be used in the coming years to show that even vacuum behaves like a material under certain circumstances — a prediction from quantum electrodynamics.
Hamburg, Germany | Posted on May 6th, 2022
The polarization of electromagnetic radiation describes in which plane in space a wave oscillates. While everyday electromagnetic radiation, such as sunlight, is unpolarized, lasers produce polarized radiation. This is an important requirement for a wide range of experiments from solid-state physics to quantum optics.
Additional polarizers, such as those being developed at the Helmholtz Institute in Jena, have the purpose of further improving polarization purity, but for a long time the limit of a few 10-10, ie, out of ten billion photons, only a handful have the unwanted polarization, could not be pushed any further. In 2018, Kai Schulze, first author of the paper now published in Physical Review Research, found that the divergence of synchrotron radiation is the reason for this limit. “So to get a further improvement in purity, we needed a source with better divergence,” says the physicist, who leads work on vacuum birefringence at HI Jena and is jointly responsible for related DFG research projects at the University of Jena. “The commissioning of the European X-ray laser, European XFEL, in Schenefeld near Hamburg set the course for this.”
Together with scientists from the Friedrich Schiller University of Jena and the Helmholtz Center Dresden-Rossendorf, Schulze and his team developed an experiment setup at the European XFEL that set a new purity record of 8×10-11 thanks to special polarizer crystals, a very precise alignment and a stable setup. This new purity record has already enabled a number of experiments on quantum optics in the X-ray range and on charge distribution in solids. However, special interest is devoted to the detection of the so-called vacuum birefringence.
The interaction of light with light was described as early as 1936 by Werner Heisenberg and Hans Euler, but has not yet been directly observed on Earth. “Vacuum birefringence is currently the most promising effect to directly detect light-light interaction,” Schulze explains. “In this process, the polarization of a sample beam changes when it collides in vacuum with a very intense second light beam. The vacuum thus acts like a birefringent crystal, which also affects the polarization; hence the name. The effect is extremely small, but grows with decreasing wavelength of the sample beam. Precise polarizers in the X-ray range therefore provide a good tool to detect the effect.”
The High Energy Density instrument at the European XFEL will provide the ideal conditions for such an experiment in the future, Schulze further explains. And the research team now has a setup with which the smallest polarization changes can be measured. The detection of vacuum birefringence would not only further underpin the foundations of quantum electrodynamics, but, if deviations from theoretical expectations emerge, also provide clues to previously unknown elementary particles (such as axions, or millicharged particles). “We hope to be able to launch the first experiments in the next few years.”
Detection of the phenomenon would also be interesting for future experiments at the FAIR particle accelerator center. “If we succeed in measuring vacuum birefringence, this will help interpret the measurement data from FAIR. Among other things, vacuum polarization will play a role there, which is closely linked to vacuum birefringence,” Schulze said.
For more information, please click here
Contacts:
Carola Pomplun
GSI Helmholtzzentrum für Schwerionenforschung GmbH
Office: 615-971-1442
Copyright © GSI Helmholtzzentrum für Schwerionenforschung GmbH
If you have a comment, please contact us.
Issuers of news releases, not 7th Wave, Inc. or Nanotechnology Now, are responsible for the accuracy of the content.
Bookmark:
Delicious
Digg
Newsvine
Google
Yahoo
Reddit
Magnoliacom
Furl
Facebook
ARTICLE TITLE
News and information
‘Smart’ diaper for bedside urine testing Peer-Reviewed Publication May 6th, 2022
‘Nanomagnetic’ computing can provide low-energy AI researchers, show May 6th, 2022
Self-propelled, endlessly programmable artificial cilia: Simple microstructures that bend, twist and perform stroke-like motions could be used for soft robotics, medical devices and more May 6th, 2022
Dynamic metasurfaces and metadevices empowered by graphene May 6th, 2022
Physics
In balance: Quantum computing needs the right combination of order and disorder: Study shows that disorder in quantum computer chips needs to be designed to perfection / Publication in ‘Nature Communications’ May 6th, 2022
New hardware integrates mechanical devices into quantum tech April 22nd, 2022
New quantum network shares information at a scale practical for future real-world applications: Researchers enable real-time adjustments to communicate among three remote nodes in a quantum network April 22nd, 2022
Quantum Physics
UCI scientists turn a hydrogen molecule into a quantum sensor: New technique enables precise measurement of electrostatic properties of materials April 22nd, 2022
Possible Futures
Reconfigurable silicon nanoantennas controlled by vectorial light field May 6th, 2022
Discoveries
Announcements
Interviews/Book Reviews/Essays/Reports/Podcasts/Journals/White papers/Posters
Oregon State University research pushes closer to new therapy for pancreatic cancer May 6th, 2022
New error mitigation approach helps quantum computers level up: New error mitigation approach helps quantum computers level up, ASCR: Quantum computers are prone to errors that limit their usefulness in scientific research May 6th, 2022
Rice ‘metalens’ could disrupt vacuum UV market: Solid-state nanophotonic technology could potentially replace cabinets of equipment May 6th, 2022
