Home > Press > Self-propelled, endlessly programmable artificial cilia: Simple microstructures that bend, twist and perform stroke-like motions could be used for soft robotics, medical devices and more
The microstructures in a radially arranged microarray , as seen here, can perform complex traveling waves of locally interacting posts . CREDIT Joanna Aizenberg/Harvard SEAS |
Abstract:
For years, scientists have been attempting to engineer tiny, artificial cilia for miniature robotic systems that can perform complex motions, including bending, twisting, and reversing. Building these smaller-than-a-human-hair microstructures typically requires multi-step fabrication processes and varying stimuli to create the complex movements, limiting their wide-scale applications.
Cambridge, MA | Posted on May 6th, 2022
Now, researchers from the Harvard John A. Paulson School of Engineering and Applied Sciences (SEAS) have developed a single-material, single-stimuli microstructure that can outmaneuver even living cilia. These programmable, micron-scale structures could be used for a range of applications, including soft robotics, biocompatible medical devices, and even dynamic information encryption.
The research is published in Nature.
“Innovations in adaptive self-regulated materials that are capable of a diverse set of programmed motions represent a very active field, which is being tackled by interdisciplinary teams of scientists and engineers,” said Joanna Aizenberg, the Amy Smith Berylson Professor of Materials Science and Professor of Chemistry & Chemical Biology at SEAS and senior author of the paper. “Advances achieved in this field may significantly impact the ways we design materials and devices for a variety of applications, including robotics, medicine and information technologies.”
Unlike previous research, which relied mostly on complex multi-component materials to achieve programmable movement of reconfigurable structural elements, Aizenberg and her team designed a microstructure pillar made of a single material — a photoresponsive liquid crystal elastomer. Because of the way the fundamental building blocks of the liquid crystal elastomer are aligned, when light hits the microstructure, those building blocks realign and the structure changes shape.
As this shape change occurs, two things happen. First, the spot where the light hits becomes transparent, allowing the light to penetrate further into the material, causing additional deformations. Second, as the material deforms and the shape moves, a new spot on the pillar is exposed to light, causing that area to also change shape.
This feedback loop propels the microstructure into a stroke-like cycle of motion.
“This internal and external feedback loop gives us a self-regulating material. Once you turn the light on, it does all its own work,” said Shucong Li, a graduate student in the Department of Chemistry and Chemical Biology at Harvard and co-first author of the paper.
When the light turns off, the material snaps back to its original shape.
The material’s specific twists and motions change with its shape, making these simple structures endlessly reconfigurable and tunable. Using a model and experiments, the researchers demonstrated the movements of round, square, L- and T-shaped, and palm-tree-shaped structures and laid out all the other material can be tuned.
“We showed that we can program the choreography of this dynamic dance by tailoring a range of parameters, including illumination angle, light intensity, molecular alignment, microstructure geometry, temperature, and irradiation intervals and duration,” said Michael M. Lerch, a postdoctoral fellow in the Aizenberg Lab and co-first author of the paper.
To add another layer of complexity and functionality, the research team also demonstrated how these pillars interact with each other as part of an array.
“When these pillars are grouped together, they interact in very complex ways because each deforming pillar casts a shadow on its neighbor, which changes throughout the deformation process,” said Li. “Programming how these shadow-mediated self-exposures change and interact dynamically with each other could be useful for such applications as dynamic information encryption.”
“The vast design space for individual and collective motions is potentially transformative for soft robotics, micro-walkers, sensors, and robust information encryption systems,” said Aizenberg.
The paper was co-authored by James T. Waters, Bolei Deng, Reese S. Martens, Yuxing Yao, Do Yoon Kim, Katia Bertoldi, Alison Grinthal and Anna C. Balazs. It was supported in part by the US Army Research Office, under grant number W911NF-17-1-0351 and the National Science Foundation through the Harvard University Materials Research Science and Engineering Center under award DMR-2011754.
For more information, please click here
Copyright © Harvard John A. Paulson School of Engineering and Applied Sciences
If you have a comment, please contact us.
Issuers of news releases, not 7th Wave, Inc. or Nanotechnology Now, are responsible for the accuracy of the content.
Bookmark:
Paper:
News and information
‘Smart’ diaper for bedside urine testing Peer-Reviewed Publication May 6th, 2022
‘Nanomagnetic’ computing can provide low-energy AI researchers, show May 6th, 2022
Highest degree of purity achieved for polarized X-rays: Helmholtz Institute Jena opens up new possibilities at the European X-ray laser European XFEL May 6th, 2022
Dynamic metasurfaces and metadevices empowered by graphene May 6th, 2022
Law enforcement/Anti-Counterfeiting/Security/Loss prevention
Turning any camera into a polarization camera: Metasurface attachment can be used with almost any optical system, from machine vision cameras to telescopes March 18th, 2022
Securing data transfers with relativity: A team from UNIGE has implemented a new way to secure data transfers based on the physical principle of relativity November 5th, 2021
Robotics
Shape memory in hierarchical networks – the astonishing property that allows manipulation of morphing materials with micro scale resolutions February 25th, 2022
How to program DNA robots to poke and prod cell membranes: A discovery of how to build little blocks out of DNA and get them to stick to lipids has implications for biosensing and mRNA vaccines October 15th, 2021
Leibniz Prize winner Professor Dr. Oliver G. Schmidt moves to Chemnitz University of Technology: President Professor Dr. Gerd Strohmeier refers to an ‘absolute top transfer’ September 10th, 2021
Govt.-Legislation/Regulation/Funding/Policy
New quantum network shares information at a scale practical for future real-world applications: Researchers enable real-time adjustments to communicate among three remote nodes in a quantum network April 22nd, 2022
Nanoclusters self-organize into centimeter-scale hierarchical assemblies April 22nd, 2022
Nylon cooking bags, plastic-lined cups can release nanoparticles into liquids April 22nd, 2022
A solution to perovskite solar cell scalability problems April 22nd, 2022
Possible Futures
Reconfigurable silicon nanoantennas controlled by vectorial light field May 6th, 2022
Sensors
UCI scientists turn a hydrogen molecule into a quantum sensor: New technique enables precise measurement of electrostatic properties of materials April 22nd, 2022
The physics of a singing saw: Insights on centuries-old folk instrument is underpinned by a mathematical principle that may pave the way for high-quality resonators for sensing, electronics and more April 22nd, 2022
Development of low-power and high-efficiency artificial sensory neurons: 3T-OTS device to simulate the efficient information processing method of the human brain. A green light for the development of sensor-AI combined next-generation artificial intelligence “to be used in life a April 8th, 2022
Discoveries
In balance: Quantum computing needs the right combination of order and disorder: Study shows that disorder in quantum computer chips needs to be designed to perfection / Publication in ‘Nature Communications’ May 6th, 2022
Announcements
Interviews/Book Reviews/Essays/Reports/Podcasts/Journals/White papers/Posters
Oregon State University research pushes closer to new therapy for pancreatic cancer May 6th, 2022
New error mitigation approach helps quantum computers level up: New error mitigation approach helps quantum computers level up, ASCR: Quantum computers are prone to errors that limit their usefulness in scientific research May 6th, 2022
Rice ‘metalens’ could disrupt vacuum UV market: Solid-state nanophotonic technology could potentially replace cabinets of equipment May 6th, 2022
Military
New hardware integrates mechanical devices into quantum tech April 22nd, 2022
Graphene-hBN breakthrough to spur new LEDs, quantum computing: Study uncovers first method for producing high-quality, wafer-scale, single-layer hexagonal boron nitride April 15th, 2022
First integrated laser on lithium niobate chip: Research paves the way for high-powered telecommunication systems April 8th, 2022
NYU physicist to lead project that aims to enhance quantum computing: Research backed by $7.5 million multidisciplinary university research initiative award April 1st, 2022
